Partial initialization
Perform partial initialization of a company file(entite/dossier) starting from the previous day.
Request Methods
POST: Trigger the partial initialization
POST /partialInit
Request URL:
POST https://api.cegid.com/loop-api-publiques/partialInit
Request Body:
The request body for the POST method should include the following fields:
| Field Name | Type | Description | Required |
key |
string | Unique identifier of the entity | YES |
subscriptionId |
string | Subscription id of the sinker | YES |
numberOfDays |
integer | Number of days for which we send the data, prior to the execution time. | YES |
numberOfDays : The maximum value allowed is 20 If not specified, the default value of the number of days is 1
Example POST Request
Example POST Request Body:
"key": "e12a5703-ef8e-48da-8a21-699af50aae80",
"subscriptionId": "7324343829320",
"numberOfDays" : 1
Example POST Response
A successful POST request should return a 200 status code and a response body as follows:
"message": "L'initialisation partielle du dossier COMPANY_ONE - domaine LOOP - a débuté",
"domain": "LOOP",
"codeIbs": "COMPANY_ONE"
