List of firm collaborators file (liste de Collaborateur Cabinet)
Pre-requisites
"Cegid Loop - APIKey Cabinet" is required This service is chargeable, check with your sales representative
The api key is generated in cegidlife on this service by a firm administrator
Settings in LoopHub, documentation in French : https://assistanceloop.blob.core.windows.net/documentation/Gestion_interne/collaboratif_catalogue_applications.pdf
The request headers must contain x-apikey, Ocp-Apim-Subscription-Key
: This is the subscription key and it is mandatory.
GET/collaborateurcabinet
Returns a collaborateurcabinet list
API Request/Response
example Code Description Links 200 class response
Media type
application/json Controls Accept header.
Therefore, all responses from the API are in the JSON format and all payloads to the API must be in the JSON format.
The request headers must contain Content-Type: application-json
Base URL
The base URL has the same structure for all public API requests. It consists of:
Domain | Mode | Role | |
Example | https://loop.loopsoftware.fr | /YPN | /cabinet |
on cegid Developers :
https://developers.cegid.com/api-details#api=loop-api-publiques&operation=getcollaborateurcabinet
For the purpose of this document, Base URL will be referred to as <baseUrl>
Request Types
The base url is followed by one of Request Types:
query
for CRUD operations on modelstransaction
for transactional requestsserverless
for requests to server functionsservice
for requests to services
Parameter
The C R UD – Retrieve resources.
"url": https://api.cegid.com/loop-api-publiques/collaborateurcabinet?codeDossier?codeDossier=cabinet
Name | Description | example | mandatory | |
codeDossier | Code Dossier | cabinet | YES | |
filter string (query) | Allows you to filter the result | identifiant=="Collaborateur_100" | NO | |
Sort | Allows you to sort the result | field1&&field2:desc | NO | |
skip | Allows to pass X elements | ?skip="{number}" | NO | |
take | Allows to recover X elements | ?take="{number}" | NO |
Note : the filter parameter should use javascript notation for equality : either == or === or !=
Class Reponse
To retrieve a single resource the request should supply the UID.
Action | Nature | Description | |
objectId | string($uuid) | ID (UUID) Code unique | |
revisionId | string($uuid) | ID (UUID) of revision | |
identifiant | string maxlengt 100 | code of dossier | |
prenom | string maxlength 100 | First name, mandatory for individual persons | |
nom | string maxLength: 100 | Name, mandatory for individual persons | |
login | string maxLength: 100 | login | |
string maxLength: 100 | Name of dossier | ||
langue | string maxLength: 100 | Code ISO 100 country | |
actif | string maxLength: 100 | active user | |
tenant | string maxLength: 100 | tenant | |
adresse1 | string maxLength: 100 | Adress1 | |
adresse2 | string maxlength 100 | Adress2 | |
adresse3 string | maxlength 100 | Adress3 | |
ville | string maxLength: 10 | city | |
codePostal | string | code zip | |
pays | string | Code ISO of country | |
telephone | string maxLength: 100 | Phone number | |
groupeTravail | string maxLength: 100 | List of working group codes associated with the folder, separated by a ; | |
responsable | string maxLength 100 | Line manager email | |
roleOrga | string maxLength 100 | Lorganizational role | |
prixVente | float | Selling price | |
prixRevient | float | cost price | |
Example response
"objectId": "81b66d46-cefb-4dae-b739-1173aae97420",
"revisionId": "0x000000000009109A",
"identifiant": "Collaborateur_100",
"prenom": "",
"nom": "COL_100",
"email": "col_100@devloop.onmicrosoft.com",
"login": "col_100_login@devloop.onmicrosoft.com",
"telephone": "",
"adresse1": "",
"adresse2": "",
"adresse3": "",
"ville": "",
"codePostal": "",
"pays": "",
"langue": "",
"tenant": "devloop",
"accesSocial": true,
"responsable": "collab@devloop.onmicrosoft.com",
"roleOrga": "Administrateur",
"prixVente": 0,
"prixRevient": 0,
"groupeTravail": "LOOP-GESTION-DES-DROITS;"
GET//CollaborateurDossierCabinet
Returns a CollaborateurDossierCabinet list
Media type
Base URL
Request Types
query
Parameter
filter string (query) | Allows you to filter the result | dossierId=="b42ba973-07ce-4c6a-873a-5509ab7a20e2" | YES | |
Class Reponse
groupeDeTravail | [...] | group | |
Example response
"objectId" : "e2b94200-11b1-4a60-b409-b19fed95d217",
"revisionId" : "0x00000000001AA454",
"identifiant" : "manon",
"nom" : "Entressangle",
"prenom" : "Manon",
"login" : "manon@loop.onmicrosoft.com",
"email" : "MENTRESSANGLE@cegid.com",
"tenant" : "devloop",
"adresse1" : "",
"adresse2" : "",
"adresse3" : "",
"ville" : "",
"codePostal" : "",
"pays" : "",
"telephone" : "",
"groupeDeTravail" : [
"code" : "MV_GT_001",
"description" : "MV GT 001",
"agence" : ""
"code" : "LOOP-RDD",
"description" : "Collaborateurs RDD",
"agence" : ""
"code" : "LOOP-GESTION-DES-DROITS",
"description" : "",
"agence" : ""
"code" : "",
"description" : "",
"agence" : ""
"prixVente" : 0,
"prixRevient" : 0,
"accesSocial" : false,
"responsable" : "",
"roleOrga" : "Administrateur",
"langue" : "fr",
"competences" : [ ]
POST/collaborateurcabinet
adding a collaborateurcabinet
POST https://api.cegid.com/loop-api-publiques/collaborateurcabinet?codeDossier={codeDossier}
Media type
Base URL
https://developers.cegid.com/api-details#api=loop-api-publiques&operation=addcollaborateurcabinet
Request Types
query
Parameter
"url": https://api.cegid.com/loop-api-publiques/collaborateurcabinet?codeDossier=cabinet
codeDossier | Code Dossier | cabinet | Yes |
On body
"login": "collab.api2@cabinettest.onmicrosoft.com",
"email": "collab.api2@cabinettest.onmicrosoft.com",
"identifiant": "test",
"nom": "TESTNOM",
"prenom": "testprénom",
"responsable": "",
"adresse1": "21 RUE JASMIN",
"adresse2": "22 RUE JASMIN",
"adresse3": "23 RUE JASMIN",
"codePostal": "75016",
"ville": "PARIS",
"pays": "FR",
"langue": "fr",
"telephone" : "01 02 00 03 04",
"tenant": "",
"roleOrga": "",
"prixVente": 45.66,
"prixRevient": 33.73,
"groupeTravail": "LOOP-GESTION-DES-DROITS"
example several files
"login": "collab.api@cabinettest.onmicrosoft.com",
"email": "collab.api@cabinettest.onmicrosoft.com",
"nom": "TESTNOM",
"responsable": "",
"ville": "PARIS",
"pays": "FR",
"langue": "fr",
"tenant": "",
"roleOrga": "",
"prixVente": 45.66,
"login": "collab2.api@cabinettest.onmicrosoft.com",
"email": "collab2.api@cabinettest.onmicrosoft.com",
"identifiant": "test2",
"nom": "TESTNOM",
"responsable": "",
"ville": "PARIS",
"pays": "FR",
"langue": "fr",
"tenant": "",
"roleOrga": "",
"prixVente": 45.66,
Information:
Attention, before adding it is necessary to do the get collaborateurcabinet in order to have objectId of the collaborateurcabinet
Class Reponse
Example response
"success": [{
"objectId": "b760550f-0a9b-4686-af1f-8bd9d6797189",
"revisionId": "0x00000000001A4696",
"nom": "TESTNOM",
"tenant": "cabinettest",
"ville": "PARIS",
"pays": "FR",
"telephone": "01 02 00 03 04",
"groupeTravail": "LOOP-GESTION-DES-DROITS",
"prixVente": 45.66,
"responsable": "",
"roleOrga": "",
"langue": "fr"
"errors": []
PUT/collaborateurcabinet
Modification of collaborateurcabinet
PUT https://api.cegid.com/loop-api-publiques/collaborateurcabinet?codeDossier={codeDossier}
Media type
Base URL
on cegid Developers : https://developers.cegid.com/api-details#api=loop-api-publiques&operation=updatecollaborateurcabinet
Request Types
query
Parameter
Example body
Information:
Attention, before modifying it is necessary to do the get collaborateurcabinet in order to have objectId of the collaborateurcabinet
"revisionId": "0x00000000001A4699",
"identifiant": "test MODIF",
"nom": "TESTNOM",
"ville": "PARIS",
"pays": "FR",
"langue": "fr",
"responsable": "",
"roleOrga": "",
"prixVente": 45.66,
Example response
"success": [{
"objectId": "5ce882dd-e1cf-4062-a3c5-40c1e839db07",
"revisionId": "0x00000000001A4691",
"identifiant": "Collaborateur_101",
"prenom": "",
"nom": "COL_101 Modification",
"telephone": "",
"adresse1": "",
"adresse2": "",
"adresse3": "",
"ville": "",
"codePostal": "",
"pays": "",
"langue": "",
"prixVente": 0,
"prixRevient": 0,
"errors": []
DEL/collaborateurcabinet
Delete of collaborateurcabinet
DEL https://api.cegid.com/loop-api-publiques/collaborateurcabinet?codeDossier={codeDossier}
Media type
Base URL
on cegid Developers : https://developers.cegid.com/api-details#api=loop-api-publiques&operation=deletecollaborateurcabinet
Request Types
query
Parameter
codeDossier string | The code of collaborateurcabinet | cabinet | YES |
Example body
Information:
"objectId" : "ad7f2403-82e1-47c6-840f-3f8f15635062",
Example response
"success" : [
"status" : "deleted",
"revisionId" : "0x00000000001A65ED"
"errors" : [ ]
